Mythic Cache Progression in Diablo 4 | U4GM Tips
Glico
Сообщение Glico »
Most players who feel stuck in Season 14 are not undergeared; they are spending reputation time in the wrong places. I made that mistake early, clearing low-value side activities while my Seasonal Board barely moved. A decent build matters, but having the right Diablo 4 gear will not fix inefficient routing. The Temis board makes your progress visible, so use it as a farming checklist rather than treating every available activity as equal.
What actually moves the Season 14 reputation bar
Campaign steps are worth doing because they unlock the seasonal loop, but they are not where repeatable progress comes from. Once Ruptures, Deathtoll Chambers, Lair Bosses, and Corrupted Reaper runs are open, rotate through whichever objective also improves your character. A fast clear on higher Torment usually beats a slow "optimal" activity where your build spends half the run waiting on cooldowns.
The repeatable Glints of Hope rewards are the real reason to care about capping the bar. Since the post-patch change guarantees Pandemonium Fragments, these caches are no longer just filler loot between major milestones. That makes reputation farming part of Mythic planning, especially for players who do not want to rely entirely on random boss drops.
My efficient route after reaching Torment
I start with objectives that overlap with a War Plan, then pick activities my build clears without changing gear or skills. A speed-oriented farming setup is better here than a boss-killing setup. Movement speed, reliable area damage, resource sustain, and short cooldowns save more time than squeezing out another small damage multiplier.
1. Complete War Plan objectives before running unrelated seasonal content.
2. Farm the highest Torment you can clear without repeated deaths.
3. Save boss materials until your reputation milestones are nearly finished.
4. Run Corrupted Reapers when their objective rewards match your route.
Grouping is useful, but only when everyone is chasing the same board objective. Random groups can become slower than solo play when one player wants Lair Bosses, another wants Ruptures, and someone else is stopping for every side event. A coordinated party sharing chest progress and synchronized War Plans is excellent. A loosely organized party is usually just extra loading screens.
Season Journey mistakes that cost real time
The biggest trap is trying to finish every chapter immediately. Some objectives complete naturally while you farm reputation, level glyphs, and gear for endgame. "Terrorize The Night" was especially annoying before its recent fixes, so check the current tracker instead of assuming an old workaround still applies. If an objective is bugged or progress is unclear, move on and let later gameplay cover it.
Do not burn Pandemonium Fragments, gold, or boss materials the moment you get them. Finish the main Journey around mid-season, then decide where your build is actually weak: survivability for higher Torment, single-target damage for bosses, or speed for reputation loops. Players chasing guaranteed Mythics at higher Journey ranks should plan around that breakpoint instead of gambling resources on every upgrade.
If your stash is thin and you want to shorten the gearing gap, buy cheap Diablo IV Items only after identifying the exact slot or aspect your build lacks, then keep farming the Seasonal Board for fragments and the rewards that support your next power spike.
