U4GM Explains PoE 2 Doedre's Undoing Frog Strategy
Добавлено: 18 июл 2026, 10:33
Abyss packs are where the PoE 2 Frogmancer stops looking like a joke build and starts feeling properly nasty. You cast Despair into a crowded lane, the first enemy drops, and Doedre's Undoing turns that curse into a burst of toxic frog spawns instead of another ordinary Hex effect. Before spending Path of Exile 2 Currency on ambitious upgrades, make sure you enjoy that reactive playstyle: this is a build that rewards aiming curses into dense packs and letting the chain begin, not standing still and summoning a permanent army.
The shield is the build, not a convenient extra
Doedre's Undoing is the reason the archetype works, so treat it as the foundation of the loadout rather than a late luxury. The important interaction is converting standard Hex application into toxic amphibian summons. When a cursed target dies, the effect detonates and can create three to five frogs at once. Those frogs stack a fast-ramping plague damage-over-time effect on durable targets, which gives the build a very different boss profile from conventional zombie or skeleton setups. Clear speed comes from repeated curse explosions; single-target damage comes from keeping enough toxic bodies active around a high-health enemy.
Build the curse link around density, then adjust for danger
Despair is the natural trigger because it casts quickly and covers enough area to start a pack chain, although another fast, wide Hex can fill the same role. Hex Bloom Support matters most while mapping because it spreads the curse as enemies die, creating more opportunities for frog spawns without extra casts. Minion Damage Support is the straightforward damage link. Unbound Ailments Support helps the poison clouds left by expiring frogs remain relevant, especially when rares refuse to fall over quickly. Meat Shield Support is the flexible defensive choice: it makes part of the swarm pull aggression away from your Witch, but don't expect it to fix poor positioning during dangerous encounters.
The common mistake is judging Frogmancer from an empty area. A lone enemy gives the build less to work with, while a packed encounter or an Abyss crack supplies the deaths that fuel its momentum. Against bosses, cast close enough that your frogs can connect, but don't chase every spawn through hazards. Their scaling also makes gearing unusual: global Intelligence and total Chaos Resistance contribute to frog health, so hybrid defensive pieces can improve more than your own survival. A wand with +1 to all Chaos Spell Gems and Minion Maximum Life is a sensible target, while rings with Minion Movement Speed reduce the dead time spent hopping around terrain.
Early progression can feel uneven because the build needs the shield interaction and enough linked support gems before its identity appears. Once those pieces are in place, prioritize reliable defenses and movement over chasing every damage roll. Faster frogs, better curse coverage, and safer casting usually improve the grind more than a tiny theoretical DPS gain. Save POE 2 Currency Orbs for upgrades that support the full loop, because Frogmancer shines when each curse cast creates pressure, control, and poison damage at the same time.
