In the competitive ecosystem of Warborne: Above Ashes, few abilities redefine engagement rules as dramatically as Raven’s kit. Designed around delayed punishment, buff denial, and stack-based empowerment, Raven embodies a playstyle that thrives on disrupting enemy momentum rather than simply racing damage numbers. Where many characters in WAA Solarbite focus on raw burst or sustained DPS, Raven instead operates as a battlefield controller—one who dismantles enemy defenses, suppresses healing, and turns prolonged fights into carefully engineered executions.
At the core of this identity are two interconnected mechanics: Raven’s Gaze, a targeted delayed AoE control tool, and Raven’s Call, a stacking passive engine that converts sustained aggression into explosive payoff. Together, they create a rhythm of setup and release that rewards patience, positioning, and timing awareness. Understanding how these two systems interact is essential for mastering Raven, especially in PvP environments where buff stacking, shields, and healing-over-time effects often determine the outcome of extended fights.
Raven’s Gaze: A Delayed Execution Tool With Hard Disruption
Raven’s Gaze is not a typical damage ability. On paper, it appears straightforward: select an enemy target, summon ravens after a short delay, deal 210% Magic Damage to up to five enemies, and apply a suite of debilitating effects. In practice, however, its true power lies not in its raw numbers but in its timing and denial package.
After a 2-second delay, ravens dive into the targeted area, creating a predictable but unavoidable impact window. This delay is crucial—it transforms the ability from a simple nuke into a psychological and positional weapon. Opponents are given a brief opportunity to react, but in chaotic PvP fights or tightly packed PvE encounters, that reaction window often becomes irrelevant.
When the ravens strike, they deliver more than damage. The ability:
Dispels all buffs
Removes shields
Deletes HoT (Healing over Time) effects
Applies a 50% slow
Reduces damage dealt by 50% for 6 seconds
Prevents targets from receiving buffs, shields, or HoT effects during that duration
This combination is what elevates Raven’s Gaze from strong to oppressive in coordinated play. It does not merely punish enemies—it strips away their ability to function as designed. Defensive rotations collapse instantly, healing windows disappear, and even damage dealers find their output halved.
In Warborne: Above Ashes, where many builds rely heavily on layered defensive uptime, Raven’s Gaze acts as a hard reset button. It doesn’t just interrupt fights; it rewrites them.
The Strategic Weight of Buff Removal
The buff removal component of Raven’s Gaze cannot be overstated. Many high-level builds in Warborne: Above Ashes rely on stacking temporary buffs to reach peak efficiency—damage amplification, barrier cycling, regeneration loops, and reactive shields are common across both PvE and PvP metas.
Raven’s Gaze directly counters these systems by removing all active buffs in a single strike. This means:
Tanks lose mitigation windows at critical moments
Healers lose sustained output from HoT effects
DPS characters lose ramping damage stacks or temporary crit boosts
More importantly, the post-impact restriction prevents reapplication, meaning opponents cannot immediately rebuild their defensive or supportive layers. This creates a vulnerability window that Raven’s team can exploit.
In coordinated group fights, this often translates into forced disengagements or sudden collapses. A well-timed Raven’s Gaze can invalidate an entire enemy rotation cycle, especially when combined with allied burst damage.
Raven’s Call: The Stack Engine Behind the Burst Window
While Raven’s Gaze defines the character’s control identity, Raven’s Call is what turns Raven into a sustained threat over time. This passive mechanic introduces a stack-based reward system tied directly to skill usage.
Every time Raven deals damage with a skill, they gain a stack of Raven’s Call. At 6 stacks, the next damaging skill used within 8 seconds triggers a bonus effect:
Ravens are summoned at the location of impact
Deal 120% Magic Damage to up to 5 enemies
Remove 1 stack of buffs from hit targets
Restore 60% Healing Rate HP to self
Has a 10-second cooldown
This system creates a cyclical gameplay loop: build stacks through consistent aggression, then convert those stacks into a burst of AoE damage, utility disruption, and self-sustain.
Unlike traditional cooldown-based burst mechanics, Raven’s Call rewards sustained engagement. Players are encouraged to remain active in combat, weaving skills together efficiently rather than waiting for singular high-impact cooldown windows.
The Hidden Strength: Self-Sustain Through Offense
One of the most overlooked aspects of Raven’s Call is its healing component. Restoring 60% Healing Rate HP upon activation effectively turns offensive output into survivability.
This creates a unique identity: Raven does not rely heavily on external healing sources to remain effective in extended fights. Instead, the character sustains through aggression, converting damage cycles into self-recovery.
In practice, this means:
Raven can remain on the frontline longer than expected for a caster-type role
Misplays are partially forgiven if stack timing is maintained
Extended skirmishes favor Raven disproportionately
This sustain mechanic also synergizes strongly with Raven’s Gaze. After stripping enemy buffs and reducing their damage output, Raven is simultaneously healing and resetting through Raven’s Call, making them difficult to dislodge once momentum is established.
The Synergy Between Gaze and Call: A Two-Phase Combat Loop
The true strength of Raven emerges when both abilities are viewed as a unified system rather than isolated skills. The kit naturally forms a two-phase combat loop:
Phase 1: Setup and Disruption (Raven’s Gaze)
Raven initiates or counters engagement by targeting clustered enemies. Raven’s Gaze lands, stripping buffs, disabling healing, and crippling enemy damage output.
Phase 2: Conversion and Sustain (Raven’s Call)
During the weakened enemy state, Raven continues casting skills, building stacks. Once 6 stacks are reached, Raven’s Call triggers, dealing AoE damage, stripping additional buffs, and restoring health.
This loop creates a repeating cycle of:
Disruption
Pressure
Sustain
Re-engagement
Over time, Raven effectively forces enemies into a state of diminishing returns. Every attempt to stabilize is interrupted, while Raven continues cycling value through repeated resets.
PvP Impact: A Controller That Punishes Greed
In PvP environments, Raven excels as a punisher of overextension and buff reliance. Many PvP builds in Warborne: Above Ashes depend on timed buff windows—burst combos, shield rotations, or regeneration cycles.
Raven disrupts all of these.
A single Raven’s Gaze landing in a team fight can:
Remove defensive pre-buffing before a burst
Disable healing during coordinated dives
Force repositioning due to slow and damage reduction
Create vulnerability windows for allied assassins or DPS
When combined with Raven’s Call, Raven becomes not only disruptive but also self-sufficient in prolonged fights. This makes them particularly dangerous in attrition-based PvP scenarios where teams attempt to outlast each other.
However, Raven’s effectiveness is heavily tied to timing. Poorly placed Raven’s Gaze can miss key targets or hit enemies outside optimal clustering. Similarly, failing to properly manage Raven’s Call stacks reduces the character’s overall impact.
PvE Applications: Anti-Heal and Anti-Buff Dominance
In PvE, Raven shines in encounters that rely on enemy buff cycles or healing mechanics. Bosses or elite enemies that periodically gain shields or regeneration effects are especially vulnerable to Raven’s Gaze.
Key advantages include:
Consistent buff stripping against boss phases
Reduced incoming damage during high-pressure mechanics
Self-sustain through Raven’s Call healing
Strong multi-target damage in add-heavy fights
The ability to remove buffs also simplifies certain encounter mechanics. Instead of reacting to layered enemy defenses buy WAA Solarbite, Raven effectively resets them on demand.
This makes Raven particularly valuable in group PvE compositions where control and utility are prioritized alongside raw DPS.
Strengths and Limitations
Like all high-impact control characters in Warborne: Above Ashes, Raven comes with clear strengths and limitations.
Strengths
Exceptional buff and shield removal
Strong AoE control and damage
High self-sustain through offensive play
Powerful in both PvP and PvE
Scales well in coordinated team environments
Limitations
Delayed execution on Raven’s Gaze (requires prediction)
Reliant on stacking for optimal Raven’s Call usage
Less effective against highly mobile or spread-out enemies
Requires awareness of timing windows to maximize impact
Raven is not a reactive character in the traditional sense. Instead, they reward foresight and encounter planning. Players who can anticipate enemy movement and group behavior will extract significantly more value than those relying purely on reactionary play.
Final Thoughts: A Masterclass in Controlled Destruction
Raven in Warborne: Above Ashes represents a design philosophy centered on control through denial. Rather than overwhelming enemies with brute force, Raven dismantles their ability to function—removing buffs, shutting down healing, and reducing offensive output before converting that advantage into sustained pressure and self-healing.
The synergy between Raven’s Gaze and Raven’s Call creates a loop that is both oppressive and elegant: disrupt first, punish continuously, and sustain through aggression. In skilled hands, Raven becomes less of a traditional damage dealer and more of a battlefield architect—one who dictates the pace and structure of every engagement.
For players who enjoy strategic control roles with high impact timing windows, Raven offers one of the most rewarding kits in Warborne: Above Ashes. It is a character that does not simply participate in fights—it reshapes them entirely.
