Pokémon Legends: Z-A Best Normal-Type Team Builds
Добавлено: 20 окт 2025, 11:07
Normal-type Pokémon often get overlooked in competitive battles due to their lack of elemental strengths, but in Pokémon Legends: Z-A, a well-rounded Normal-type team can be surprisingly versatile. Their high attack stats, access to a variety of status moves, and broad coverage make them a solid choice for players who want a dependable team without relying on type advantages alone. Here’s a detailed look at the best Normal-type team builds and strategies to consider.
Key Strengths of Normal-Type Pokémon
Before diving into team compositions, it’s important to understand what makes Normal-types unique in Pokémon Legends: Z-A. They are generally known for:
Versatility in Moves: Many Normal-types can learn moves from other types, allowing for creative coverage against opponents.
High Base Stats: A number of Normal-types boast impressive attack or speed stats, making them suitable for aggressive strategies.
Stability in Combat: With fewer weaknesses compared to some specialized types, Normal-types are generally easier to manage in battles.
Recommended Normal-Type Pokémon for Your Team
Here’s a breakdown of some standout Normal-type Pokémon for building a competitive or casual team in Z-A.
1. Staraptor
Staraptor is a fast and hard-hitting Pokémon that thrives on physical offense. Moves like Brave Bird and Close Combat complement its speed, and with access to Quick Attack, it can handle faster threats in the late game. Staraptor fits well as a lead or mid-game attacker.
2. Blissey
Blissey serves as a reliable tank and healer. Its massive HP and access to moves like Soft-Boiled make it excellent for stalling or supporting teammates. Pair Blissey with offensive Normal-types to keep your team balanced.
3. Slaking
Slaking is a powerhouse thanks to its incredible Attack stat. While its Truant ability limits consecutive attacks, careful switching and support from other team members can make it a devastating late-game sweeper.
4. Porygon-Z
Porygon-Z adds a special attack dimension to a Normal-type team. With moves like Tri Attack and Hyper Beam, it can deal with a variety of threats. Consider pairing it with an item to boost its survivability.
5. Silvally (Normal-Type Form)
Silvally offers flexibility and utility, as it can adapt to different situations with multi-type coverage. Its Normal-type form is especially strong when you need a balanced attacker that can fit into any team.
Team Composition Tips
When building your Normal-type team in Z-A, aim for a mix of physical attackers, special attackers, and defensive supports. A sample balanced team could look like this:
Lead: Staraptor for speed and early pressure.
Wall/Support: Blissey for healing and stalling.
Physical Sweeper: Slaking for raw power.
Special Attacker: Porygon-Z to handle diverse threats.
Utility: Silvally for type coverage.
Flex Slot: Another versatile Normal or hybrid Pokémon depending on your strategy.
Strategy Considerations
Status Moves: Moves like Thunder Wave or Toxic can give Normal-types an edge, slowing opponents or gradually wearing them down.
Item Choices: Items like Choice Band, Life Orb, or Leftovers significantly impact performance. Consider each Pokémon’s role carefully.
Coverage Against Weaknesses: Even Normal-types can struggle against strong Fighting-types. Including moves that counter these threats ensures longevity in battles.
Normal-type Pokémon in Pokémon Legends: Z-A can be deceptively strong when assembled into a strategic team. Their combination of raw power, flexibility, and support options makes them a great choice for trainers looking to build a well-rounded squad. For those aiming to enhance their team further, you can explore opportunities to buy Shiny Pokemon ZA or check out a za best pokemon shop to find rare and valuable options that complement your strategy.
Building a Normal-type team isn’t just about brute strength; it’s about synergy, adaptability, and knowing when to strike. Mastering these elements will make your Normal-type team in Z-A both formidable and fun to play.
1. Staraptor
2. Blissey
3. Slaking
4. Porygon-Z
