How should I take Lamivudine?
Добавлено: 24 май 2024, 07:09
Some drugs should not be taken together because they might have dangerous effects or stop the drug from working as well. Tell your doctor or pharmacist about all the prescription and nonprescription medications you are taking, including vitamins, minerals, and herbal products. Also, tell them if you are planning on getting pregnant or breast-feeding. Your doctor can recommend safer ways to protect yourself from pregnancy while taking lamivudine manufacturers in india.
Lamivudine is in a class of drugs called nucleoside reverse transcriptase inhibitors (NRTIs). It works by blocking the synthesis of DNA inside the cell, thereby stopping virus replication. It is used in conjunction with other antiretroviral agents to treat HIV infection and to help prevent the spread of the infection to others.
Pomalidomide manufacturers can also cause a dangerous build-up of lactic acid in the blood (lactic acidosis). This condition is more likely to happen if you have certain medical conditions, are pregnant or are breastfeeding, or are older than 60 years of age. You may also be at a greater risk for developing this condition if you have had previous liver damage or kidney disease.
