MMOexp:Diablo 4 Season 14 War Plans Break the Leveling Meta
Anselmrosseti
Сообщение Anselmrosseti »
The race to Level 70 is one of the most exciting parts of every new Diablo 4 season, and Season 14 completely changes the leveling meta. Thanks to the new War Plans progression system, players now have several highly efficient routes that can dramatically reduce the grind.
Instead of endlessly farming the same content, Season 14 rewards players who understand how War Plans interact with different activities. Whether you're aiming to compete on the Hardcore ladder, prepare for Torment difficulty quickly, or get your seasonal character online as fast as possible, there are now three primary strategies worth considering.
Each route offers different advantages depending on your experience level, diablo 4 gear, and tolerance for RNG.
Strategy 1: Hell Worm Farming – The Fastest Leveling Method
If pure speed is your goal, Hell Worm farming is currently the strongest leveling strategy available.
When everything goes perfectly, experienced players can reach Level 70 in approximately 90 minutes. More realistically, most players can expect a completion time between 1.5 and 2 hours.
The entire strategy revolves around unlocking the Hell Worm experience globes through the War Plans tree.
Rather than simply clearing monsters normally, players invest their first War Plan points into the Hell Tide branch, eventually unlocking the upgrade that causes Hell Worms to spawn powerful XP globes. These globes provide enormous bursts of experience, often granting multiple character levels from a single spawn.
Once unlocked, the gameplay changes completely.
Instead of killing every enemy in sight, players build their Hell Tide Threat meter to roughly 50%, follow optimized spawn routes, trigger Hell Worm encounters, collect the massive experience rewards, then repeat the process.
The experience gains become absurd.
During successful practice runs, players reported spending nearly an hour reaching the required War Plan unlocks before jumping from the low twenties all the way to Level 70 in roughly forty additional minutes.
The strategy does come with several drawbacks.
Because your character gains levels much faster than gear upgrades, monster scaling quickly outpaces your equipment. You'll frequently need to return to town to purchase stronger weapons and armor from vendors just to maintain your damage output.
Hardcore players should also be cautious.
Hell Tide is significantly more dangerous than other leveling methods, and constantly managing Threat, spawn locations, and difficulty scaling requires much more attention.
Optimizing the Early Game Before Level 25
The first twenty-five levels are critical.
Before Level 25, War Plans can only roll two activity types:
Hell Tide
Dungeons
This limited activity pool can actually be manipulated.
Players should continuously reroll War Plans until they receive double Hell Tide objectives whenever possible. Since there are only a few possible combinations, the odds are surprisingly favorable.
Some players even recreate fresh characters until they begin with ideal War Plans, saving valuable time later.
Perhaps the most surprising optimization is intentionally avoiding experience.
While it sounds counterintuitive, rushing to Level 25 too early actually delays access to the second War Plan point needed for the Hell Worm strategy.
Many experienced players intentionally leave XP globes on the ground and continue farming on Normal difficulty until they secure the second War Plan upgrade. Once unlocked, they immediately transition into full Hell Worm farming.
This delayed progression creates a much stronger power spike later.
Difficulty Swapping Maximizes War Plan Progress
Another trick involves changing world difficulty at specific moments.
Many players complete Hell Tide farming on Normal for speed and safety, then switch to Penitent difficulty only when opening Hell Tide chests.
Why?
Because higher difficulties award significantly more War Plan activity experience.
Opening chests on Penitent grants roughly 50% more progression than opening them on Normal, accelerating access to important upgrades while keeping combat manageable.
Once the Hell Worm engine is online, players can gradually increase difficulty based on their build strength.
Strategy 2: Undercity Farming – The Most Consistent Route
Not everyone enjoys the high-pressure Hell Tide strategy.
Fortunately, Undercity offers an excellent alternative.
Although this method cannot begin until Level 25, it is considerably easier to execute and requires far less planning.
After unlocking Undercity, players complete three or four quick runs to earn their first War Plan point for the mode.
That upgrade unlocks Jade Epiphany experience globes.
These globes function similarly to Hell Worm rewards by granting enormous chunks of experience based on your Attunement level during each run.
The process is straightforward.
Rush through the dungeon toward the boss, activate enough braziers to maintain movement buffs, clear sufficient monsters to maximize Attunement, then collect the experience globes before finishing the run.
At maximum Attunement, a single collection can provide more than half a level even well beyond Level 50.
Unlike Hell Tide, Undercity requires almost no map management.
There are no Threat meters to monitor.
No spawn routes to memorize.
No complicated rotations.
Simply repeat efficient runs and watch your levels climb.
Most players can comfortably reach Level 70 within two hours using this method.
With additional optimization, experienced runners may even approach the 1 hour 45 minute mark.
Undercity Is Safer for Hardcore Players
Another major advantage is survivability.
Enemy density remains manageable, incoming damage is lower, and progression feels much smoother throughout the leveling process.
Movement-focused builds become especially effective thanks to permanent shrine effects obtained from braziers.
Teleport, Shadow Step, Dash, and other mobility skills allow players to fly through each dungeon with minimal downtime.
For Hardcore characters, this lower-risk environment makes Undercity one of the safest leveling strategies available.
Strategy 3: War Plans Experience Rewards
The third leveling method is less specialized but offers excellent flexibility.
Instead of focusing exclusively on Hell Tide or Undercity, players simply pursue the largest War Plan experience rewards available.
Every completed War Plan grants activity progression, experience globes, and randomized bonus rewards.
Rather than chasing one optimal activity, players complete whichever objectives provide the highest experience returns.
Hell Tide remains one of the strongest options overall due to its combination of loot and XP, while Infernal Hordes are generally considered less efficient for pure leveling.
Although this route is slower—typically requiring between 2.5 and 3 hours—it provides several long-term benefits.
Players naturally unlock more War Plan branches, gain broader progression across different activities, and enter Torment difficulty with significantly more systems already developed.
For players focused on long-term seasonal progression rather than leaderboard racing, this balanced approach may actually provide the strongest overall start.
Seasonal Content Could Change the Meta
One unknown variable is Season 14's new seasonal mechanics.
Practice testing was performed using Season 13, meaning new Hell Tide events introduced this season could dramatically improve—or slightly reduce—the effectiveness of current leveling routes.
If the seasonal content generates additional Threat quickly, Hell Worm farming could become even faster.
Likewise, adjustments to War Plan progression rates may allow players to unlock important upgrades earlier than expected.
As players continue testing after launch, the optimal route will likely become even more refined.
Which Strategy Should You Choose?
Each leveling route serves a different type of player.
Competitive players looking to push leaderboards should master Hell Worm farming, as it offers the fastest possible route to Level 70 despite requiring careful execution and some favorable RNG.
Players who prefer a smoother, more relaxed experience will likely enjoy Undercity, which delivers outstanding leveling speed with far less complexity.
Meanwhile, those interested in building complete seasonal progression while still leveling efficiently can simply prioritize War Plan experience rewards across multiple activities.
Regardless of your choice, Season 14 significantly reduces the traditional leveling grind. Smart use of War Plans, Diablo IV Items for sale, and efficient experience management allow players to reach endgame content faster than ever before, making the journey to Torment both shorter and far more rewarding.
