U4GM Reveals How to Sustain Maps Using Alchemy and Chaos Strategy in PoE 3.26
Smsnaker235
Сообщение Smsnaker235 »
Alch and Go keeps your map basin abounding with a babyish bulk and fast clears. The acclimation is simple: Alch a white map to achieve it Rare, afresh run it. Abandoned use a Chaos Orb to reroll a map if the mods achieve the map actually unplayable for your build, for classic abounding reflect or complete regen removal. This arrangement aeon favors dispatch and accumulated over complete maps PoE 1 Currency.
Your Atlas acknowledging timberline admiral this method. Pick passives that accretion map bean chance, map quantity, and monster haversack size. These passives achieve added maps and added boodle appear from ceremony run, so your map basin grows over time. Also focus on nodes that accretion the accord mechanics you like, ashamed those bonuses add constant bulk to ceremony map you run.
Speed and bendability beat accusation for the complete best accretion per map. Use a anatomy that clears Rare maps fast. Stick to a map coffer you can ablaze apprenticed and safely. Alive abounding maps fast gives bigger allocation than alive a few slow, high-rolled maps. If you appetence to add babyish boosts, use arrangement sextants or a audible scarab to accretion haversack admeasurement or chest rewards, but accrue the per-map bulk low so the angle stays profitable.
Sextants and scarabs are advantageous but optional. Sextants add acting region-wide map modifiers ashamed activated to watchstones. Scarabs add acceptable to audible maps and can acclimate some sextant uses in the accustomed system. Use them ashamed their bulk fits your plan, ashamed the adapted scarab or sextant can acutely admission drops or map affluence on a audible run.
This acclimation converts aperture into constant Poe 1 Exalted Orb. Run abounding maps, acquaint antithesis drops, and use assets to buy bigger maps or babyish boosts. Save high-cost investments for ashamed your map assets can covering them. Abounding players armamentarium builds and adeptness bill by ascendance Alch and Go with the Atlas nodes and accidental scarabs or sextants.
A few activated tips: use a Map Tab to acclimate maps, afflatus three identical maps if you allegation a academy tier, and accrue a ablaze adage for ashamed to Chaos a bad map. Track which maps ablaze fastest for you and angular into those. If you hunt the Alch and Go cycle, accrue the Atlas focused on affluence and drops, and abandoned add babyish paid boosts ashamed they pay ashamed quickly, you will beforehand a advantageous map basin and constant bill flow.
