In Elden Ring, the diverse range of builds allows players to customize their playstyle in unique ways, and one of the most intriguing options is crafting a poison-based strategy. Poison can be a devastating tool when used correctly, slowly draining the health of enemies and making them vulnerable over time. If you're looking to exploit poison in your next playthrough, here are 12 of the best builds designed to maximize this toxic tactic.
1. Poison Mage Build
The Poison Mage build focuses on using the power of poison magic to inflict steady damage. By combining poison sorceries like Rotten Breath with strong intelligence scaling, you can unleash a wave of toxic clouds that slowly break down enemy health. This build works especially well in areas with many groups of enemies, allowing you to hit multiple targets at once.
2. Toxic Archer Build
Using long-range poison-infused arrows, this build keeps you at a distance while still causing immense suffering to your enemies. By equipping poison-tipped arrows and a bow, you can keep your opponents poisoned and at bay. It’s especially effective against bosses that are slow and have trouble reaching you.
3. Poison Dual-Wielder Build
For those who love getting up close and personal, the Poison Dual-Wielder build can deal substantial poison damage. By equipping dual daggers or curved swords with poison infusion, you can quickly apply the status effect and follow up with high-speed attacks to ensure your enemies suffer continuous damage.
4. Poison Faith Build
A hybrid of poison and Faith, this build combines the power of poison-infused incantations with high healing and defensive buffs. Incantations like Swarm of Flies will poison nearby enemies, while your Faith scaling ensures that your defensive abilities, such as Golden Vow, increase your survivability.
5. Poison Tank Build
Tank builds aren’t just about raw strength; they can be built to endure and spread poison as well. Using heavy armor, a great shield, and poison-infused weapons like the Poisonous Mist ability, this build allows you to endure hits while poisoning enemies with each successful strike or breath attack.
6. Poison Sword and Shield Build
This build incorporates the defensive power of a shield while using a poison-infused sword for offense. By blocking with the shield and striking when an opening presents itself, you can slowly apply poison to your enemies without taking too much damage in return.
7. Rotten Warrior Build
This build is all about the rot. Utilizing weapons like the Rotten Battle Axe or Giant-Crusher with poison/rot infusion, your attacks inflict poison and scarlet rot. It's perfect for aggressive players who want to overwhelm their enemies with both immediate damage and long-term poison effects.
8. Poison Bleed Hybrid Build
By combining poison and bleed effects, this build creates a deadly synergy. Weapons like the Bloodhound's Fang or Reduvia can be paired with poison-tipped arrows or poisons applied through weapon coatings. The result is a constant barrage of damage, both immediate (through bleed) and over time (through poison).
9. Stealth Poison Assassin Build
For players who prefer a stealthy approach, this build focuses on getting in close and poisoning enemies before they have a chance to react. With high dexterity and the Sneak Attack ability, you can deliver powerful poison strikes using daggers or poison-infused weapons. It’s a hit-and-run style of play that can quickly whittle down enemy forces.
10. Poison Pyromancer Build
For those who enjoy the fiery side of things, the Pyromancer build can incorporate poison spells and infusions with fire-based damage. By using spells like Poison Mist or Fire’s Deadly Sin, you can overwhelm enemies with a combination of burn and poison damage. It’s a powerful strategy for areas filled with groups of enemies or large bosses.
11. Poison Tank and Mage Hybrid Build
This build merges the power of a tank with the utility of magic, giving you the ability to both take and deal poison damage. With a large shield and poison-infused magic weapons, you can protect yourself from incoming attacks while gradually applying poison to your enemies. It’s the perfect blend of survivability and poison damage output.
12. Poison Ninja Build
For those who prefer a light, fast build, the Poison Ninja build focuses on speed and agility. Using weapons like Poisoned Kukris or Twinblades, you can dart in and out of combat, applying poison with each quick strike. This build allows for maximum mobility, letting you hit hard and retreat quickly before your opponent even realizes what’s happening.
Poison-based builds offer a unique, methodical way of dealing with enemies in Elden Ring. Whether you prefer to take your time with a stealthy poison approach or go all-out with a rot-infused tank, there’s a build that suits every playstyle. To level up your character for these strategies, consider getting ahead of the grind and buy Elden Ring runes PC to quickly enhance your stats and gear. Alternatively, if you're on console, you can always buy Elden Ring items PS4 to acquire the right tools for your poison-based journey. Embrace the power of poison, and let it eat away at your foes as you dominate the Lands Between!
Top 12 Elden Ring Builds for Poison-Based Strategies
Re: Top 12 Elden Ring Builds for Poison-Based Strategies
The main advantage of accurate LHP is the freedom to explore different positions comfortably. In missionary or cowgirl positions, the alignment feels natural, with minimal awkward adjustment. In positions like doggy style, proper LHP means the angles match human anatomy, making the experience more intuitive. For photography, accurate placement allows for more realistic poses, enhancing visual appeal. If your American sex doll has a flexible skeleton, the combination of poseability and correct LHP opens up many possibilities for experimentation. Post-use cleaning is essential for hygiene and to extend the lifespan of your sex dolls cheap.
My faithful lover milf sex doll.
